VAG-COM is a software package for Windows that emulates the functions of the dealers\\\' very expensive proprietary scan tools.VAG-COM will work with most Volkswagen and Audi models sold World-Wide 1994 through 2008. It will work with some cars all the way back to model year 1990. It will also work with most late-model SEAT, and Skoda models sold in markets other than North America.
VAG-COM is the first aftermarket VAG-Tool that:
* Is fully compatible with all VW, Audi, Seat and Skoda models through 2008, including models using a direct CAN connection for diagnostics.
* Has a database of more than 9000 fault-codes and measuring-block texts.
* Can use the new 7-Digit PIN/SKC codes to match new keys in all immobilizer equipped VW/Audi/Seat/Skoda models.
* Allows you to view, log, and graph 3 groups of Measuring Blocks at once
* Can access all control modules which require proprietary VAG modes running the new KWP-2000 protocols (2001+ Teves Mk.60 ABS, numerous 2002+ modules)
* Can display critical timing information on TDI engines in graphic form
Included:
* VAG-COM 409.1
* VAG-COM 512.4
* VAG-COM 607.3
* VAG-COM 704.1
* BDM 100
* BMW M35080
* BMW Scanner 1.36
* EDC 16 ECU Flasher
* Galletto 1250
* HC908 Programmer
* HC912 Programmer
* HC705 Programmer
* MB Carsoft 7.4
* MB key maker
* MC711 Programmer (MC68HC(7)11 EEPROM programming tool)
* NEC Programmer
* Opel Immo Reader
* Opel Tech 2
* T-Code 300
* TMS 370
* T-PROG + software
* USB ELM327
* Vag Prog dongle
* VAG CAN Commander v5.1 full
* VAG Tacho USB 1.7
* VAG Tacho USB 2.2
* VAG Tacho USB 2.5
* VIS 2.0 (Vag Info System)
* VW/AUDI Airbag Reset
