Klappschlüssel umbauen?
Diskutiere Klappschlüssel umbauen? im 1M - Tipps & Tricks Forum im Bereich Der Leon 1; No - I would not go for the G version... go for the DA, especially because somebody already tested that one with a like model... as for the symbol...
  • Klappschlüssel umbauen? Beitrag #881
No - I would not go for the G version... go for the DA, especially because somebody already tested that one with a like model... as for the symbol - that one you can get also via dealer - or here (eBay link), "custom made" ;)
  • Klappschlüssel umbauen? Beitrag #882
:tremblin:
ok, thanx for the advice
I am now searching for the DA one, but is very hard to find one below 30 euros
  • Klappschlüssel umbauen? Beitrag #883
Where are you from? UK?
  • Klappschlüssel umbauen? Beitrag #885
Ahhh - okay... I was wondering because there are some +/- cheap offers on ebay UK but probably you do not see them because of the shipping options...
  • Klappschlüssel umbauen? Beitrag #886
I see
these seems like a good deal about 35 euros all inclusive
  • Klappschlüssel umbauen? Beitrag #888
I ordered a complete 1J0 959 753 DA, it is from a skoda,
I have a question, can I let the transponder programmed for my toledo
or do I have to buy a new transponder wicht is particularly for the seat
in other words are the transponders the same type
  • Klappschlüssel umbauen? Beitrag #889
If you are lucky it will work (lucky in this case means: the key has not been attachend to another car yet and the transponder is of the correct type for your car) - if not you can take one of the transponders out of your existing keys, e.g. the key without remote functions (just be careful not to destroy the transponder in the process - hot water helps to get the key apart and also to extract the transponder) - I had also a Skoda type transponder, but that one did not work with my Leon...
  • Klappschlüssel umbauen? Beitrag #890
transponder in my current key can be very easily removed, i just checked :D
but is it easy to put it in a flip key
  • Klappschlüssel umbauen? Beitrag #891
Very easy ;)
1. Remove the Badge on the front part of the key - e.g. with a pointed knife
2. Remove the screw underneath
3. Take the key apart (be careful the spring does not fly away :D )
4. Get the tranponder out of the compartment (it is glued in there - might need some brute force)
5. Put the working transponder inside (with some glue)
6. Reassemble the key (you might need to try out in which direction you have to coil the spring for the flip key to work properly)
7. Glue a new badge to the key - part number 1M0 837 891 A JGT
  • Klappschlüssel umbauen? Beitrag #892
Very easy ;)
very helpfull image, things are clear now..
I just got a mail from the seller, the transponder is brand new and never programmed
  • Klappschlüssel umbauen? Beitrag #893
You will have to wait until you get the key - mine said the same ;) (and probably also said the truth - it's nor easy to find a working transponder)
  • Klappschlüssel umbauen? Beitrag #894
ok good to know, I think will just use my current transponder, I do not need 3 keys
2 is enough
  • Klappschlüssel umbauen? Beitrag #895
Also ich interessiere mich auch dafür mir einen Klappschlüssel zuzulegen. Hab mal nachgefragt bei meinem Seat Händler, und der meinte, sowas kann man auch sofort bei Seat bestellen. Kostet so um die 40€. Dann ist er auch schon fertig und programmiert.
Meine Frage ist nun, wie kann man sich so ein Schlüssel selber machen? Das Metallteil muss ja gefräst werden damit man es ja im Zündschloss drehen kann.
Und ist es da nicht einfacher den original Klappschlüssel von Seat zu bestellen?
  • Klappschlüssel umbauen? Beitrag #896
40€? das kann ich kaum glauben.
ich habe schon alleine 38,60€ nur für die Sendeeinheit des normalen Schlüssels bezahlt!
  • Klappschlüssel umbauen? Beitrag #897
Das is das was er mir gesagt hat. Er kuckt das nochmal genau nach, aber er denkt das müsste so in dem Bereich liegen.
  • Klappschlüssel umbauen? Beitrag #898
Also DAS glaube ich auch nicht. Der Schlüsselbart inkl. Transponder kostet ca. 40 EUR und die Sendeeinheit nochmal so viel. Ich glaub der hat sich verguckt.
  • Klappschlüssel umbauen? Beitrag #899
Also wenn er das für den Preis verkauft bin ich sofort dabei !
  • Klappschlüssel umbauen? Beitrag #900
Hab meinen auch vom :] ,hat ca 100Eur gekostet.
Klappschlüssel umbauen? - Ähnliche Themen
[ST]
184 PS DSG
Unsichtbare Verbesserung Seat-Soundsystem: Nach 5 Jahren mit einem Dynaudio-Werkssystem in einem VW Scirocco war ich skeptisch, ob das Seat-Soundsystem in meinem neuen Leon SC Cupra da...
Jason'z weißer FR: Hallo Leute, ich will mal kurz meine Geschichte zu meinem Löwen erzählen: Ich bin letztes Jahr rein zufällig auf den Seat Leon gestoßen. Davor...
