Media-System USB-Anschluss
Diskutiere Media-System USB-Anschluss im 5F - Interieur Forum im Bereich 5F - Tuning; nein!
  • Media-System USB-Anschluss Beitrag #21
nein!
  • Media-System USB-Anschluss Beitrag #22
Duffy, Dein beschriebenes Problem habe ich auch .. manchmal merkt er sich den letzten Titel, manchmal beginnt er bei der 1. Cd und 1. Titel ...
ich setz noch einen drauf ... es kommt vor, dass ich das Auto mit Radio ausmachen ... nach dem Starten beginnt aber nicht der Radio zu laufen, sondern Media ... aber auch umgekehrt tritt das auf.
  • Media-System USB-Anschluss Beitrag #23
Hi all,
sorry for english, but I am not German. :)
I found out that I have a problem loading my USB stick in my Media System (high, but not navi). When I start motor, radio do not see any USB pluged in, even I did not touch it in glovebox. This happend occasionaly, roughly 50% of radio starts.
I have to get USB stick out of the USB plug and plug-in it again to read it again, but this is really uncomfortable. I am using USB 3.0 stick. Will it be with USB 2.0 better?
Anybody else with this problem?
Any solution?
Thanks
  • Media-System USB-Anschluss Beitrag #24
Many people have that problem, including myself. Have been using USB 2.0. The only solution (that is working for me) is to use an SD-card instead of the crappy USB-thing. Then the system occasionally forgets the play mode (e.g. "mix mode"), but at least it always finds the SD card and remembers the last played file.
Mm.
  • Media-System USB-Anschluss Beitrag #25
Thanks for reply.
If using SD card - is any readable limitation of the size of SDHC card? In manual I see limitation only for SD card (less than 2GB), but no limitation for SDHC.
Will be 64GB SDHC readable?
PS: Sorry, 32GB is max for SDHC, 64GB is SDXC format :) So, 32GB will be readable?
  • Media-System USB-Anschluss Beitrag #26
Yes, sounds good. I am using an 128 GB card by Platinum, SDXC, class 10 (whatever that means). Works fine for me.
Mm.
  • Media-System USB-Anschluss Beitrag #27
Aaa, SDXC also supported, ok, thanks! Better to use one bigger card as not working USB sticks. Play mode is not such a problem.
I see it in manual also - SDHC or SDXC supported.. :)
  • Media-System USB-Anschluss Beitrag #28
Good luck my friend. Keep us informed, will you?
Mm.
  • Media-System USB-Anschluss Beitrag #30
Higher Class = higher read/write rate in MB per second.
Only important for copying files from PC to SD-card. Should not affect audio-players such as the car's media system.
  • Media-System USB-Anschluss Beitrag #31
I don't know since I've been using other sticks, but all of them had that problem.
Those on the list may be hard to get though.
Won't try because the SD card is good.
Mm.
  • Media-System USB-Anschluss Beitrag #32
Thanks for sharing information.
As my USB stick yesterday was not loaded again, I have decided to go in SD card. Bought , size 128GB, and working good. Hope loading problems will not be repeating with SD card as well..
  • Media-System USB-Anschluss Beitrag #33
Seems to be a good choice. Tell us if it's okay!
Mm.
Media-System USB-Anschluss - Ähnliche Themen
Einstellung der Systeme bei Tieferlegung?: Hallo zusammen, ich bin seit letztem Wochenende stolzer Besitzer eines Seat Leon Sportstourers mit 150 PS TDI. Diese haben als Sommerfelgen...
Digitales Cockpit - keine Einstellungsmöglichkeit?: Hallo Zusammen, habe seit letzter Woche einen Seat Leon FR TSI 1.5. Mittlerweile habe ich das Infotainment System und das Digitale Cockpit soweit...
Motor 1.4 68Kw dreht aber springt nicht an: Hallo zusammen, ich hoffe, ihr könnt mir weiterhelfen. Mein Seat Leon 1P, 1.4 (68KW) springt plötzlich nicht mehr an. Folgendes konnte ich...
Carplay / Bluetooth: Hallo zusammen, ich habe zwei iPhone's (dienstlich & privat) und fahre seit März, den Seat Leon Sportstourer FR 2.0 TDI 110kW (Modelljahr 2023)...
Defektes 5QA 035 846 MIB Std2 ersetzen: Hallo zusammen, Ich habe folgendes Problem. Habe in meinem Seat Leon BJ. 2017 das Media System 5QA 035 846 SW 0245 HW H24 mit dem Display 5F0...
