Technical Question : How to install the BRAKE PAD SENSOR to get it work on 1J5920846C
Diskutiere Technical Question : How to install the BRAKE PAD SENSOR to get it work on 1J5920846C im 1M - Fahrwerk & Räder Forum im Bereich 1M - Tuning; Hi boys, today with my friend cardealer we checked out my front driver's wheel and we established that I DON'T HAVE ANY BRAKE PAD SENSOR..in the...
  • Technical Question : How to install the BRAKE PAD SENSOR to get it work on 1J5920846C Beitrag #1
M206
Hi boys, today with my friend cardealer we checked out my front driver's wheel and we established that I DON'T HAVE ANY BRAKE PAD SENSOR..in the old leon tacho i got the icon that blink at the turn on but only to check the led of the icon..:(
So i've to install this sensor..I've already saw that there is the brake pad itself with the sensor included as an aftermarket part, but my problem is: where to install that cable and connector??They go to CCM or not???(
If is it so, where exactly it has to be connected in the CCM???(
We also checked and haven't see any connection plug located beside the brake pad..I know that usually there is a plug on the brakepad which will be plugged into a housing which is not far away from it..
in this worst case, (that i've no predisposition cable) i'll have to install the housing and the cable too..from where could i start??which parts do i need?? ?(
Do someone has already done this upgrade? ?(
Could i install it??
Do you get the ETKA code of this sensor/wirings/cables and drawings so that i can buy it from my carseller and then install it???(
Can someone help me??:baby:
Thanks a lot.
byez;)
  • Technical Question : How to install the BRAKE PAD SENSOR to get it work on 1J5920846C Beitrag #2
AW: Technical Question : How to install the BRAKE PAD SENSOR to get it work on 1J5920846C
I think nobody did ever so much work for a small light into the Dash.
If you Pads are gone, you will hear it.
Peter
  • Technical Question : How to install the BRAKE PAD SENSOR to get it work on 1J5920846C Beitrag #3
thank you for your smart reply..:rolleyes: :rolleyes:
Technical Question : How to install the BRAKE PAD SENSOR to get it work on 1J5920846C - Ähnliche Themen
Sometime Motor don’t start: I've this issue with my seat Leon 2018 FR 1.4 TSI, recently after changing a timing belt and Oil pressure value, the start stop sometimes does not...
Information Stehbolzen/Muttern: //DE Guten Morgen, Ich wende mich an Sie, weil ich im Internet nicht viel finden kann. Ich würde gerne Stehbolzen/Muttern (Stehbolzen...
Cupra 290 (2019) - Bizarre Bluetooth scenario with iPhone: Greetings my friends from Germany Firstly apologies for jumping onto the German Leon forum, I am from Ireland and well unfortunately we lack a...
QI charging question: Hi Sorry that I write in English but your language is not native for me. I see that your Leon 4 community is huge thats why I want to about QI...
Hi to all from Croatia: As i research a lot on the Leon audio upgrade i found here some topics that are helpfull and here i, m. I have a Seat Leon FR + 1.5TSI ACT 96kw...
