retrofit ACC adaptative cruise control
Diskutiere retrofit ACC adaptative cruise control im 5F - Tipps & Tricks Forum im Bereich Der Leon 3; comment that is valid for golf Wolksvagen VII need: * , Radar supported: 5Q0907561 [img] http://i58.tinypic.com/2saea0j.jpg [/ img] * , Rack...
demonjrm
need:
[url]http://i58.tinypic.com/2saea0j.jpg[/url] [/ img]
* , Rack radar: 5F0 853 667 C 9B9
[img] [url]http://i58.tinypic.com/mc7jlw.jpg[/url] [/ img]
* 2 screws M6 / 100: N101 635 05
[img] [url]http://i59.tinypic.com/rc3htw.jpg[/url] [/ img]
* 5 rivets
* 10-pin: 000 979 009
[img] [url]http://i60.tinypic.com/9un0ps.jpg[/url] [/ img]
* Connector radar: 4F0972708
[img] [url]http://i61.tinypic.com/25s3frl.jpg[/url] [/ img]
* , Wiring: 2 x 2x0,35 stranded, positive, negative
[img] [url]http://i60.tinypic.com/1624db4.jpg[/url] [/ img]
4 stealer
[img] [url]http://i61.tinypic.com/23u21w7.jpg[/url] [/ img]
Plate for the support beam radar or Original: 5F0807109B
[img] [url]http://i59.tinypic.com/29ws3rq.jpg[/url] [/ img]
, Switch to ACC: 5Q0953513AG
[img] [url]http://i62.tinypic.com/js0yhj.jpg[/url] [/ img]
first, you need to remove the bumper
[img] [url]http://i62.tinypic.com/24bjmlt.jpg[/url] [/ img]
[img] [url]http://i61.tinypic.com/25au343.jpg[/url] [/ img]
[img] [url]http://i57.tinypic.com/9t36ko.jpg[/url] [/ img]
For which you have no ACC manufactures missing you like my structure for supporting the radar,
, So here's what I've done fabricarmela with a 3mm aluminum plate 11.4 cm x 22 cm, which would have put the radar bracket to mark the holes, just in case, at the opposite end I made the 5mm holes also in case; these holes 5mm ... I happened to a male thread 6/100 to put the original screws ref N 101 635 05
[img] [url]http://i60.tinypic.com/2m6s46w.jpg[/url] [/ img]
once we have the plate ready, mark the center of the crossbar which are about 4 cm 46,5cm and mark the left and right to subsequently put 3 rivets to secure the plate to the cross, once we make the holes 5.5mm.
mark the centers to the plate and present it to the back of the beam leaving the threaded holes 38 cm of soil and well centered, we do drills and rivets. IT IS VERY IMPORTANT TO LEAVE WELL PLATE AND FOCUSED RIGHT HEIGHT.
[img] [url]http://i59.tinypic.com/348nbwh.jpg[/url] [/ img]
I made myself wiring, for that I bought a few rolls of 0.35mm cable 10 meters:
2 orange rolls
1 gray
1 red
1 brown (it had to be white, but I have not found)
one black
must braiding orange / gray and orange / white (in my case brown)
the connector ref: 4F0 972 708 8-pin
put the pins, plus we've put a piece of insulating termoretractil to make it better
[img] [url]http://i60.tinypic.com/2dkebg9.jpg[/url] [/ img]
[img] [url]http://i58.tinypic.com/2nrmwex.jpg[/url] [/ img]
[img] [url]http://i62.tinypic.com/2romhz5.jpg[/url] [/ img]
I've also [adslot]first[/adslot]covered with tape anticalórica also it will protect
The pinout is as follows
black to pin 1
gray to pin 2
Orange orange / gray to pin 3
white to pin 5 (in my case brown) -------- This goes to pin 7 of the camera
Orange orange / white to pin 6 ----------- This goes to pin 1 of the camera
red to pin 8
[img] [url]http://i60.tinypic.com/33aw495.jpg[/url] [/ img]
We will place the wiring and connect the connector on the radar, so we put it next to the water tank wiper connector down
[img] [url]http://i59.tinypic.com/352n9xx.jpg[/url] [/ img]
below we take the connector and had next to the thermostat wire,
[img] [url]http://i60.tinypic.com/aorpd2.jpg[/url] [/ img]
took the cable from behind the bar, I have fastened with a stub sticker inside the crossbar and down the cable to the camera plate, place the connector in place.
[img] [url]http://i62.tinypic.com/2hyksvl.jpg[/url] [/ img]
is so
[img] [url]http://i60.tinypic.com/2gya9t1.jpg[/url] [/ img]
We will replace the grid by having the window for radar, for this we press the pins with a screwdriver and let pressure by hand to go disengaging the grid
[img] [url]http://i57.tinypic.com/kdltl2.jpg[/url] [/ img]
[img] [url]http://i59.tinypic.com/qzm44i.jpg[/url] [/ img]
Once removed, place the new ref: 5F0 853 667 C 9B9
we put the bumper without forgetting connect the fog and whoever has PDC system.
This will already looking something !!! : banana:
[img] [url]http://i58.tinypic.com/2u43jp3.jpg[/url] [/ img]
now we have to put the wiring inside the Cabin
for this we will remove the battery, as this just behind the rubber grommet, he punctured with a screwdriver to put a guide into the car and with it the wires
[img] [url]http://i58.tinypic.com/2ui9m38.jpg[/url] [/ img]
[img] [url]http://i62.tinypic.com/20kq5jm.jpg[/url] [/ img]
[img] [url]http://i59.tinypic.com/wuqyqc.jpg[/url] [/ img]
once we have the wires inside, we have to upload to the camera, remove the left top of the dashboard and release the plastic of the left pillar (where the tweeter) has 4 staples, shooting from the top backwards, will pressure
[img] [url]http://i58.tinypic.com/104oky0.jpg[/url] [/ img]
[img] [url]http://i62.tinypic.com/33bioeq.jpg[/url] [/ img]
[img] [url]http://i59.tinypic.com/2uopie1.jpg[/url] [/ img]
pass the cables through the edge of the upholstery of the roof, removing it from the glass just enough to between cables, now let's remove the casing of rain and light sensor, and it's there housed the camera comes out easily by forward pressure and then down over 4 staples.
[img] [url]http://i60.tinypic.com/nz108x.jpg[/url] [/ img]
after removal finished route the cables to the camera
[img] [url]http://i60.tinypic.com/24dhbnc.jpg[/url] [/ img]
Now we pressure down the camera in the most part to the connector next release, a loose once, release the connector.
[img] [url]http://i61.tinypic.com/2ciimgl.jpg[/url] [/ img]
[img] [url]http://i57.tinypic.com/5npr9e.jpg[/url] [/ img]
we get the record of pins of the housing to place the cables where they belong:
Orange orange / white (in my case brown) to pin 1 of the camera
white (in my case brown) Orange / White on pin 7 of the camera
orange orange / gray with orange / brown pin 2 of the camera
gray orange / gray with orange / gray pin 8 of the camera
black with brown pin 5 of the camera
red with yellow / red pin 6 of the camera
[img] [url]http://i57.tinypic.com/2sec9.jpg[/url] [/ img]
[img] [url]http://i59.tinypic.com/2lizdsn.jpg[/url] [/ img]
to put the wires on pins 1 and 7 put them before the pins on the ends, all other connections have used stealer.
Once all the connections we put the wires and put the camera back
[img] [url]http://i59.tinypic.com/2drt0md.jpg[/url] [/ img]
put the housing back and now go with the replacement of switches and coding
for this we will start removing the airbag, for it will turn the wheel we put a screwdriver into the hole as you can see in the photo, to press the wire and release the 1st leg of the airbag, do the same operation with the other side
[img] [url]http://i60.tinypic.com/59uf85.jpg[/url] [/ img]
I used a cell phone to guide me and see the wire but also you can use a small mirror, simplifies work than having to do it blindly
.Now Put straight the steering wheel and disconnect the positive of the battery to avoid shocks to the airbag (I've done it before without removing a terminal of the battery) advise remove.
However, once loose pins airbag pulling proceed to remove the
[img] [url]http://i62.tinypic.com/2n4rnm.jpg[/url] [/ img]
soltais connector multifunction buttons
[img] [url]http://i61.tinypic.com/2dlqkyg.jpg[/url] [/ img]
Now release the connector ring, for it threw the lock tab, and pulling it out easily
[img] [url]http://i61.tinypic.com/vya8fc.jpg[/url] [/ img]
we have the airbag removed recommend [b] care when menajemos airbag ring [/ b] is quite fragile. Let's take the wheel to do the 1st and very important we make a mark at the screw / wheel as seen in the photo, for when we have to tighten to put it quits in the same position,
[img] [url]http://i60.tinypic.com/hwhgtj.jpg[/url] [/ img]
remove the center screw
[img] [url]http://i61.tinypic.com/vnchhe.jpg[/url] [/ img]
LEAVE OPPOSING ARROWS as in the photo and put masking tape or cellophane in the ring so that we avoid that turn, we will keep opposing arrows at all times.
[img] [url]http://i61.tinypic.com/t83xh5.jpg[/url] [/ img]
Now remove the 2 screws in front and one down, once we removed the screwdriver pry the union of the two covers, I did which were located the 2 screws
[img] [url]http://i59.tinypic.com/2l3j9s.jpg[/url] [/ img]
We took all connectors, whites easily go gently pry the tab and the yellow and red below must release the lock, also come easily
[img] [url]http://i58.tinypic.com/2gwubv9.jpg[/url] [/ img]
once released all connectors we will carefully remove the ring airbag, for that 1st remove the screw from the bottom and 2 got the two tabs is above, what desencajamos and once disengaged from the two tabs 3rd we can extract .
[img] [url]http://i61.tinypic.com/5vrri8.jpg[/url] [/ img]
We can now make the module handles pulling straight out and removing the screw before there by the bottom
[img] [url]http://i60.tinypic.com/73hvlh.jpg[/url] [/ img]
put the module or modules of the new handles and perform all the operation in reverse order
once put everything everything we reconnect the terminal of the battery, when the ignition they will be 50 failures and more lights than berbena Dove but not be alarmed if ye left facing arrow ring at all times there will be calibrated the gyro sensor and all failures picture is off when we walk in a straight line without exceeding 20 km / h for a few meters (explained later as to readjust the rotation sensor) if someone changes the ring airbag or not him off the fault of the picture.
then spent the VAG to clear all faults
such that it is becoming so
[img] [url]http://i62.tinypic.com/2pzehad.jpg[/url] [/ img]
[img] [url]http://i58.tinypic.com/ioq69k.jpg[/url] [/ img]
the post is still under construction, ire making modifications and coding
31.12.2014
Schau mal hier: retrofit ACC adaptative cruise control . Dort wird jeder fündig!
Stange
Egal was es kostet, der Aufwand steht ja wohl in keinem Verhältnis zum Nutzen…!
C280
C280
tolle Bastelanleitung für angehende Ingenieure. Für den Normaluser eher kaum zu schaffen....Aber wer doch ---> Respekt!
demonjrm
the cost is :
radar 90€ ebay
switches for ACC 80€
wires 12€
grill for radar 46€
connector radar 5€
Waldix
Waldix
Danke für die top Anleitung ;)
Black_8_ball
Really great work. And seems not to be too expensive.
But I do have concerns about the retrofit of the support beam. It could be a legal problem in germany because there are changes on a important part of the crash structure. Sure only in case if you use the "cheaper" solution not to exchange the support beam.
And I really hate the "stealers" for the electric installation. But this is just my personal feeling.
Regards B_8_B
okram
So ein Aufwand ist das nicht. Besonders wenn man schon den Fahrspurassi hat. Dann sind die Hebel am Lenkrad ja schon da.
Intressant für Gebrauchtwagenkäufer die es haben mögen. Eine anständige Werkstatt sollte die ganze Sache in 4-5 Stunden erledigt haben.
Erfahrungsberichte würden mich interessieren.
demonjrm
almost 3 hours, 45 minutes and 2 hours switches the radar and installation
Calucha
Calucha
Great instruction. Thanks for the work.
If i had DSG, i could install it without thinking about it.
And its not as expensive as i supposed. I think most workshops won't do it, since there is no official instruction for it...
Browning
Just found this installation instruction. But I still have some questions because I do not see the benefit off it.
You got the FrontAssit showing up at the MFA and the ACC menu at the radio display. But I do not see any comment if the ACC works correctly?! The meaning of ACC is to get the distance between your car and the car in front off you. Does this work?
How did you manage to adjust the front radar? Would be great tho get some feedback on those questions.
Thx
Thomas
rici1280
Ist es bei manuellen Getriebe auch möglich?
retrofit ACC adaptative cruise control - Ähnliche Themen
  • Stauassistent
    Stauassistent: Hallo Leute, da dies mein erster Beitrag in diesem Forum ist, bitte ich euch etwas Nachsicht walten zu lassen, falls ich irgendwas übersehen...
  • WARNUNG - OBD11 und Facelift ACC Sensorik - NICHT verwenden
    WARNUNG - OBD11 und Facelift ACC Sensorik - NICHT verwenden: In jüngster Vergangenheit kamen einige Leute auf mich zu, bzw auf Facebook konnte man ein Phänomen beobachten! Facelift Leon mit "plötzlich"...
  • Stauassistent
    4f0972708
    seat leon 5f acc nachrüsten
    seat leon digital cockpit retrofit
    seat leon adaptive cruise control understanding
    , acc leon retrofit, can you upgrade a SEAT leon to adaptive cruise control, 4f0972708 golf
