Leon mk3 problems with retrofit rear pdc / ops
Diskutiere Leon mk3 problems with retrofit rear pdc / ops im 5F - Allgemein Forum im Bereich Der Leon 3; Hi! I'm sorry to write in English because I do not understand or speak Deutsch ... Hope you do not mind! So my issue is the PDC / OPS parking...
PaveKoo
Hi!
So my issue is the PDC / OPS parking retrofit kit from cars-equipment.com
Now I have the kit and everything else is ok, but you can not get any signal to head unit screen?!?
So those optical "lines" do not show up.
10 park / steer assist has been coded 0000050001 at the
moment ... so I have Leon without camera, without acc and manual gear box. So I activated those three options in 5F Infotainment> Adaptation.
So everthing seems to be ok, but still that ops doesn't work ...
I have full auto-scan from vcds if you want to ... 5f module ...
That autoscan shows no error in any module.
Control module which came with that kit is 5Q0919283F .... so I think it's newer version than in marlop's guide in clubseatleon.net forum BRICO : Sensores de aparcamiento traseros + OPS (OEM) • Club de Propietarios del Seat Leon ... could that be a problem? And that module was a new one, but I got it coded I think
In 10-park / steer assist module in vcds in long coding helper has two options for BAP ... version 3.3 and version 4.0 .... Only coding for v. 4.0 works ... if I try to change coding for BAP v. 3.3 it says "request out of range" and can't be coded .... could that be a problem ?? If that control module is too new and it needs BAP v. 4.0 but my car is older and needs v. 3.3 ..... Those are my thoughts only because of this seems to be very weird ...
Thanks in advance if someone could help me in any way !!
And greetings from Finland !!!
29.08.2019
Schau mal hier: Leon mk3 problems with retrofit rear pdc / ops . Dort wird jeder fündig!
Leon mk3 problems with retrofit rear pdc / ops - Ähnliche Themen
  • [ST] Original Mittelarmlehne im leon nachrüsten
    [ST] Original Mittelarmlehne im leon nachrüsten: Hallo, kann mir Jemand sagen wie die verbaute Mittelkonsole im 5F, also der Teil mit Handbremsaufnahme und Becherhalter ausgebaut wird? Hab keine...
  • Seat Leon 5f klappern im heckbereich
    Seat Leon 5f klappern im heckbereich: Seat Leon 5f 1.4 tsi 125ps Hi, da ich mich nun seit einem Dreiviertel Jahr damit rumkämpfe,schon gefühlt 100x bei meinem Seat vertragshändler...
  • Neues Auto und gleich ein Kratzer
    Neues Auto und gleich ein Kratzer: Hallo Zusammen, ich hätte heute mein neues Auto abholen können aber habe gestern einen Anruf bekommen, dass ein 3 cm langer und sehr tiefer...
  • Seat Leon (ST) mit 4Drive, kein Cupra / XPerience | Heckschürze hinter Kennzeichen in Wagenfarbe
    Seat Leon (ST) mit 4Drive, kein Cupra / XPerience | Heckschürze hinter Kennzeichen in Wagenfarbe: Hallo liebes Forum, 1. Ich habe gesehen, dass es den "normalen" Leon z.B. als 150PS Diesel, DSG, mit EZ 2019 auch als 4Drive gibt, ohne Cupra /...
  • Probleme mit Bordnetzsteuergerät nach AHK
    Probleme mit Bordnetzsteuergerät nach AHK: Hallo, habe an meinem Seat Leon 5f eine Anhängerkupplung nachrüsten lassen. Habe jetzt das Problem , dass mein Bordnetzsteuergerät ein Wackler...
  • Probleme mit Bordnetzsteuergerät nach AHK - Ähnliche Themen
    leon led retrofit forum
